Audiolic
- Feb 23, 2012
Any mod on the magni to make it a competitive product versus 500 dollars amps..
opamps or others
opamps or others
opamps or others
opamps or others
Buy an Asgard and put a Magni sticker on the front?
Alternatively, you might try putting a blanket over it and have a third party tell you that they plugged you into a really expensive amp....
Cheers
The Magni does have a particular sound to it.
I agree, it's louder!
Cheers
I think you'd probably agree different amps have different sounds, right?
Then why would I step up to Asgard, or any of your other amps?
Because you have an aluminum fetish. Or, more seriously, because you want a Class-A, no-overall-feedback design, or because you want tubes, or because you want balanced outputs. Or because you want more capability, like preamp outs.
Magni has made me become quite intrigued with further Schiit products.
Maybe you have stumbled upon the real reason for the Magni
So, in other news, I won an iFi Micro iCan. If my Magni doesn't trade/sell before then, I'll be doing some comparing!
If it means anything I purchased an O2 before Magni, though only kept it around a few days after hearing this Schitt.
What did you prefer with the Magni, besides things like 1/4" jack and RCA input?
Mostly the output power and driving authority was noticeable straight away with Magni.
Yeah, the Magni has a ton of juice.
To me O2 sounds a touch thin in the midrange, a little too relaxed in bass. With a lot of my headphones it made the mid-range recessed fractionally.
It's funny. Those recessed mids are exactly why I'm selling my Magni. Do you mind if I ask what your Magni # is? I've heard rumors of Schiit adjusting the Magni between later and earlier versions to make it less bright. Maybe its screwing with the mids...
I think another deal breaker with O2 for me was when I switched the amp into high gain I would get distortion unless I lowered my source volume. It's all logged on the JDS website something about the maximum input signal O2 can take. I don't think that's very buff for an amp that was designed to be so legendary.
I can't tell you how much flak I've gotten from the O2's devotees over this issue. When I paired it with the ODAC on high gain, I got horrible distortion driving the HD650. Glad to see someone else for whom it was an issue too!
