Schiit Magni Headphone Amplifier
May 20, 2013 at 3:08 AM Post #1,606 of 2,252
May 20, 2013 at 3:10 AM Post #1,607 of 2,252
Are there any cans you lot know of which pair notoriously well with the Magni for under $800 or so? Do you think HD700s or TH600s for example, would warrant a better amp than the Magni?
If you have $800 to spend, consider Kingsound KS-H1 electrostatic phones with its dedicated solid state M-10 amplifier.
http://www.kingsaudio.com.hk/kings_headphone.html
Both units are available combined as a package for $800.
http://www.moon-audio.com/headphones/kingsound-headphones/kingsound-electrostatic-headphone-1.html
I haven't heard them, but initial comments about them are so promising that the phones are worth investigating, especially if you have $800 to spend.
May 21, 2013 at 11:23 PM Post #1,609 of 2,252
Ok I just bought this amp to go with my Mixamp and akg k702 Annies. Any suggestions on setting this up? Would I max the Mixamp and use the magni volume control to adjust volume? Any other hints would be appreciated.
May 22, 2013 at 12:52 AM Post #1,610 of 2,252
Turn all digital volume controls all the way up, adjust volume via amplifier. It'll allow you to hear the least amount of noise floor from the gain of the amplifier.
May 27, 2013 at 3:38 AM Post #1,612 of 2,252
Hi.
I'm French so sorry for my poor English.
I've got a modi and a magni, and I want to know if I can use my magni with my Sennheiser HD 25 C II (70ohms) without any problem ? And if the sound can be great or not with this combo (with my iMac and sound in flac).
http://www.thomann.de/fr/sennheiser_hd25_c_ii.htm
I know this is not the best headphone for hifi and amp (It's my djing headphone), but for a noob like me it's enough for the moment.
Thanks.
May 27, 2013 at 1:57 PM Post #1,613 of 2,252
Hi.
Thanks.
The Magni/Modi won't do any harm to the headphones, whatsoever. I can't say if they're a good match because I haven't heard the HD25 on the M/M.
Just wanted to let you know not to worry about damaging the headphones. If anything, they're happier with the clean power.
May 27, 2013 at 3:32 PM Post #1,614 of 2,252
Thanks.
I can try my HD 25 without any fear.
Another noob question, i want to connect my modi to my amplifier and also to my magni.
For that, i have 2 like this :
Connect on my modi, just for have 2 output instead of one. So one for my magni and one for my amplifier.
Is my solution right ?
My question is to know if this RCA adaptator can be damage the sound ?
And if you know some good RCA adaptator like this one (mine is very cheap, 1,5$)
Many thanks.
May 27, 2013 at 6:50 PM Post #1,615 of 2,252
Thanks.
Many thanks.
I bought a MonoPrice RCA-to-3.5mm and it cut out all the time and gave me nothing but problems... I then spent a lot more on a reliable cable and I think it was totally worth it. The cable is an AudioQuest Evergreen RCA-to-3.5mm, it was $27 but the build quality is beyond any other cable I've bought.
http://www.amazon.com/Audioquest-Evergreen-Audio-Interconnect-4inches/dp/B005VQGQE2/ref=sr_1_3?ie=UTF8&qid=1369694814&sr=8-3&keywords=rca-to-3.5mm+evergreen
If you want a more affordable option, then I heard that Mediabridge is decent. But I would really recommend going with the Evergreen based on my experience.
http://www.amazon.com/Mediabridge-Stereo-Design-accommodates-SmartPhones/dp/B004YEBK66/ref=sr_1_1?ie=UTF8&qid=1369694840&sr=8-1&keywords=rca-to-3.5mm
Also, what kind of Amp are you planning to hook the Magni/Modi up to, and what are you trying to do?
Hope this helps and I hope I answered the question.
May 28, 2013 at 4:57 AM Post #1,616 of 2,252
Hi guys ,
Apart from what is quoted I also saw some others that have this question as well including myself. For me I would prefer the 230V to 16Vac but 1 thing I am not sure is the male plug size that is going into the amp . do they have specific size ?
Anyone mind to chip in here ? give some examples maybe? I have tried to contact schiit but they are not much help by saying they are not in the position to advice .... which is disappointing
I do not prefer step down as they are kind of like an additional equipment and can be quite annoying .
cheers.
If you get the stack from your Local Schiit distributors, they should have provided you with a step-down transformer.
I'm based in Singapore, Got the Stack with a free transformer from my local distributor some times back.
Hi,
Thanks for the info, mind telling me where to get and how much are they going for in SG ?
 To answer my own question and THANK YOU for those that has chipped in . I have purchased the SCHIIT STACK and the MAGNI comes stock with ->>>
. No Step Down or what so ever necessary ( for those who runs 220V ) . !
May 28, 2013 at 10:59 AM Post #1,617 of 2,252
Ignore my last post...I see what you're trying to do now and the cables I provided won't do what you're asking.
Your solution should work though, but I would still look into higher-quality components.
May 28, 2013 at 4:49 PM Post #1,618 of 2,252
If you know a same adaptator like mine but in highter quality, tell me.
I have good rca cable, good usb cable, good amplifier and speaker, sound in flac on my computer, a good DAC (modi), the only low quality part is this rca adaptator that i would like to change.
May 28, 2013 at 7:54 PM Post #1,619 of 2,252
Maybe try this RCA splitter by AudioQuest. Like I said, AudioQuest is top notch.
http://www.amazon.com/AudioQuest-splitter-female-15-24cm-cable/dp/B000GUSQJG/ref=sr_1_1?ie=UTF8&qid=1369785201&sr=8-1&keywords=audioquest+rca+2+female+to+male
