Description is incorrect. Heinz & Kaufman didn't manufacturer any tubes, they used white label tubes from several different manufacturers, both European, and USA. The country of origin on the tube is normally correct though. i.e. I have a pair of E180CC PWs, that say made in Holland, which is correct, as they have the Heerlen date stamp.
I would therefore guess those are either GE, Sylvania, or Raytheon. If they're GE, they're overpriced. If they're black plate Raytheon, I'd say go for it. Just compare the construction against the same tube from those manufacturers, and you should find which one they are.
and FWIW, they don't seem to know very much about a lot of tubes, I had a recent conversation with Dave from Viva via email when I enquired about some 6n3p, and he didn't know much about them, and asked if I had any info he could use, so I spent the time to send him a load of info on manufacturers, years, and construction types that I'd learned, and he didn't bother to say a word back, and then sent a really douchey reply when I called him out days later on not bothering to even say thanks...
Edit, as far as I can find, they didn't produce these types, they did manufacture other types early on apparently.
https://www.radiomuseum.org/dsp_hersteller_detail.cfm?company_id=9832
