nwavesailor
- Nov 14, 2009
Got a reply from Schiit CS and the Max knobs are not the same diameter or shaft length as on the Lokius.
Just as I thought.Got a reply from Schiit CS and the Max knobs are not the same diameter or shaft length as on the Lokius.
IYO, is the 'market limited' because most use software for EQ?I’m going to pick one of these up… while the market seems limited, it’d be nice to see more of these types of EQs available.
What component's do you have connected to the Lokius? I find the Lokius to be really transparent. I'm using mine with a Dave and there is no lose of resolution or transparency.I'm going to be sending my Lokius back. I just got Hifiman Arya and noticed the Lokius collapses the Soundstage which is just not going to cut it.
How long have you ran the lokius?I'm going to be sending my Lokius back. I just got Hifiman Arya and noticed the Lokius collapses the Soundstage which is just not going to cut it.
It hasn't been turned off since I got it. I definitely don't have other power supplies laying around. Considering I got the Arya v2 for the Soundstage this is absolutely a deal breaker when it comes to the Lokius. It's a great device and a bummer for sureThe only time I noticed any type of difference like that was when I first got it, try leaving it on for a full day and see if it makes a difference. I would also check your power supply, try swapping it out if you have another one laying around
It's going back. If Schiit had a longer return policy I'd hold off. Thanks thoughYou need to burn in the Lokius for a bit. I had your exact same setup and didn't have your issues but if your not happy with it you are probably better off returning it
Quoting to show pictures. I ordered these knobs in black and received them. However I don't have a Lokius anymore. If anyone is interesting I paid $20 so that's what I'm asking, I'll pay shipping. US only pleaseI never liked the stock knobs on my Lokius, so I replaced them with the set of aluminum ones. IMO they look much better, partially because they don't have the alignment issues like those my unit came with.
Here's the link for those who decide to do the same swap. A black version is also available.
*For some reason the link opens correctly on my PC only with the Shift key
