Schiit Lokius Impressions & Reviews
Mar 26, 2022 at 7:46 PM Post #181 of 305
Love Schiit but both of these fixed freq EQ's are simply limited. Even if they have no audible negative effects I've never owned a Headphone (15+) or speakers (35+) that could have had all of their frequency domain issues solved - and really not even close. Wheras a parametric EQ can get it right or certainly closer. My digital toneboosters (UAPP) cost about $5. Well worth it.
Mar 26, 2022 at 7:47 PM Post #182 of 305
^^^ Probably. I have the Loki, and prefer it over software. The additional 2 bands make the Lokius more desirable. An 8 or 10 band EQ would even be better.
Parametric x4.
Apr 26, 2022 at 8:56 PM Post #183 of 305
Hey guys,
I recently got the ho200 and su 9 from smsl and really enjoying them. However, as an audiophile basshead, I miss the slam from the Xtra bass switch on my ifi idsd micro signature. Thinking about adding in either the lokius or the zen can (or zen dac-- not sure why ifi has so many products that seem redundant).
Anyone have both in line?
Apr 26, 2022 at 11:57 PM Post #185 of 305
Yup, my guilty pleasure as well to dial in just a bit more bass!
I add a little to the Sus, LCD-5 and T+A, P
Do you use the zen dac/can wirh the extra bass, or does the lokius provide some good bass slam? I prefer the XLR connection for lokius, but kike the true bass and potential to use 3d effect from ifi. I tried using my signature to feed the ho200 this evening, but it muted the bass. Must not work through the rca out. The zen dac does though. I could feed the su9 from rcs and then go xlr from su9 to ho200. Open to suggestions.
Apr 27, 2022 at 5:13 PM Post #186 of 305
That's affirmative, ZEN DAC applies its bass boost to RCA outs, but XBass+ on iDSD Signature was tailored specifically for its headphone outs. Thanks!
Apr 30, 2022 at 7:37 PM Post #187 of 305
Hi guys, I picked this up for EQ: https://www.amazon.com/gp/product/B000BTM0YO/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
However, when my DO200 is on high setting, this added some background noise. When I drop to "Mid" power output, the noise goes away, so I guess that's a solution. So, I guess my question is does the Lokius add any noise? Wondering if there is something to add in the mix to get rid of the noise, but then it seems silly to have some many things in line.
May 11, 2022 at 11:13 AM Post #188 of 305
My thought is...any addition will add to the noise. Whether you/we can hear it or not, that is the question. I don't hear any added noise when I have the Lokius in my headphones system, active or bypassed.
May 20, 2022 at 7:37 AM Post #189 of 305
Anyone tried the lokius between a high end DAC (Cambridge Audio Azur 851n or CXN) and a Mcintosh amp using XLR ?
May 20, 2022 at 9:25 AM Post #190 of 305
I’m using my Lokius between my Chord DAVE and McIntosh MHA200 without issue.
May 24, 2022 at 1:25 AM Post #191 of 305
so the Bypass mode is totally transparent ? is it giving any added value to the Mc sound value ? are you using XLR connection ?
Thanks
May 24, 2022 at 5:12 AM Post #192 of 305
Thanks
Yes, I’m able to tweak the sound to my taste with no loss of sound quality with the Lokius. I can’t imagine my system without it. I’m using both the RCA and XLR output to two separate amps, my GS-X MK2 and MHA200. Switching amps is flawless.
May 24, 2022 at 5:20 AM Post #193 of 305
Thanks and good to hear
May 24, 2022 at 5:28 AM Post #194 of 305
May 24, 2022 at 7:19 AM Post #195 of 305
No problem, it’s a great little analog device. It’s definitely worth a tryout.
Wished it was a stock item but seems I have to wait a bit for my order to ship.
