On second thoughts maybe I should post it here as it might help others avoid the same problem:
My Jotunheim headphone amp is with the repairer just now and the diagnosis isn't good. Resistors in the output stage, along with the output stage itself are all toasted, so a complete new board will need to be ordered in and installed.
I'm not quite sure how it happened TBH, but the repairer suspects dodgy wiring either in the headphones or headphone extension cable I was using at the time the fault occurred.
Let me run through the chain of events:
- I bought the used Jot in April and worked fine until the day I toasted it.
- In May I had a 6.3mm male to 6.3mm female single-ended extension cable and a 4XLR male to 4XLR female balanced extension cable made to order, to allow me to more easily connect/disconnect my headphones.
- I mainly use the amp's 4XLR output, so the 4XLR extension cable gets the most use. However I do use the 6.3mm extension cable with my Focal Utopia, and I also tried the Audio Technica ATH-ADX5000 on it, and there were no problems with either.
- Last week I got a pair of Sennheiser HD660S on home demo. Played them for a few hours on the Jotunheim via the 6.3mm single ended extension cable, no obvious problems. Did the same the next day, again no obvious problems. Played them for longer on day 3 but didn't actually listen to them as they played, just left them to 'burn in' whilst I went about my other business. Came back later that evening and found that my metaphorical 'burning in' the headphones was literally burning out my headphone amp! I'm embarrassed to admit it took me a further hour to realise this, as I initially thought the antiseptic/chemical odour was wafting in from outdoors (I had the windows open at the time). Once I realised it was the amp I powered it off straight away, but the damage had obviously long been done by then. The entire chassis of the amp was too hot to keep your hand on for more than a couple of seconds.
As I said above, the amp is currently with its repairer. However I am still in possession of the headphones and my extension cable, which I am understandably hesitant to connect to my other headphone amp in case I end up toasting that too!
I'd be grateful for advice on how to troubleshoot the source of problem. e.g. is there a way to test the wiring of my extension cable with a basic multimeter to see if there's a short somewhere? I've unscrewed the female REAN 6.3mm socket covering to visually inspect the wiring but it's smothered in so much hot melt glue it's difficult to the connections properly.
