GrussGott
- Sep 18, 2016
That's pretty cool, I think your body is acting as an antenna for the 60hz buzz!
You can try the same experiment but put a rca cable in the input and you should notice the buzz volume get louder the closer you the move the rca cable near your power cables. (tape or cover the other end of the rca so you don't get any loud surprises)
One of those cheap skinny RCA's should be less shielded and pick up more noise and act as a more sensitive antenna, you'll be able to find RF noise all around your home: anything with an inverter, your cell phone, wifi routers, etc.
Hmmm, tried that with my extremely cheap 6' rca-trs cord and got no response at all - only when I touch the volume pot and it doesn't matter what I do with the open end of the RCA cable. I even laid the rca cable over the power cord of a running air purifier - no 60 hz hum, only when I touch the volume pot.
I remain impressed at how much this Jot cleans up the sound - it's a lot more than I experienced out of the house and this is only single ended.
I'm going to play a month or so and then build a balanced HD600 cable ... not sure I have the guts to chop off the end of my TH-x00M, but I might grow a pair after I build the 600...
