EraserXIV
- Dec 5, 2008
mispost
Wyrd question (ha)-
LPS and USB power separation aside,
I'm curious whether the magic chip that Mike M loves to do the USB re clocking will ever be added onto the USB card within BiFrost DAC?
Seems a natural next step.
I believe they've already said that isn't the plan, since most people wouldn't benefit from it, so why do so and have to raise the price.
I would imagine that even making it an optional component would be a problem, since they'd have to redesign the board.
Or...maybe it could be a different Uber USB option. Uber USB+decrapifier.
Now people must have lots of Wyrd's in hand. I got mine delivered today and I know many others already got theirs.
Is it time to start a Wyrd impressions thread? If nothing else it would be cool to keep track of how how the Wyrd affects different sources and DAC's.
I was skeptical, but am a believer now...
Because? Preliminary review - it decreases noise?
I did not notice a change in noise level, but here's some VERY early impressions after only about an hour of listening:
- Apple Macbook Air -> Amarra -> Wyrd -> Hugo -> Lyr 2 -> HD800(stock) and Paradox Slants and Noble Switch PR in the R configuration:
With Wyrd, the highs seem less strident. Smoother, but not darker. Just less harsh. As you can imagine, the HD800's on the Lyr 2 can be pretty harsh and bright. On recordings that are prone to sibilance and pain on some highs are actually not sibilant and bearable using the Wyrd. The difference is more noticeable than I expected. I am sure I could tell in a blind A/B test.
- Apple Macbook Air -> Amarra -> Wyrd -> Geek Out 450 -> Lyr 2 -> HD800(stock) and Paradox Slants and Noble Switch PR in the R configuration:
In this case, I think there's even more difference. It's wyrd though that the output level seems to be louder when the Wyrd is in the loop. That doesn't make any sense though, but maybe the internal volume of the GO changes when I plug it into the Wyrd vs. the Macbook USB port. The difference is basically the same as with the Hugo, but I think there may be more bass impact with the Wyrd. On the highs, it's definitely smoother and less harsh with the Wyrd.
Anyway, I figure if I can hear the difference, then other more experienced listeners will definitely hear it and be able to describe more accurately the differences when they hear it.
Really smoothes out those 1s and 0s, huh?
Probably not the 1 and 0's, but RF, electrical noise and other such hash from poor computer layouts.
Exactly—it removes noise and interference. It doesn't "smooth out the highs." Schiit themselves say they don't know how/why it would make the music sound different.
