schneller
- Jan 14, 2007
Are you comparing BF/64 at all here?
No, sorry.Are you comparing BF/64 at all here?
Yes and no. As far as I know current Gungnir being sold now is the same analog section with Unison USB, but due to parts shortages it is missing the VXCO reclocker and has to make do with only VCO. It has serial numbers starting with L. That said, I use that Gungnir with my Folkvangr and it sounds fantastic.I once owned a gungnir MB gen5 from 2017. I believe it was the A2 board. I kinda miss it quite a lot now and consider getting another one to pair with the new FV. Is the current Gungnir actually the same version just a newer USB input?
Except for Unison USB I guess not. It still sounds fantastic though, and if you want one with the Analog Devices chips I suspect now is the time. I absolutely do not regret buying one in 2022 at all.I see. Looks like no significant upgrade in 5 years. Any rumor that a new upgrade or sidegrade version is coming soon?
Jason did say in a live stream that they may have to transition to a version powered by TI chips, but that's about it.I see. Looks like no significant upgrade in 5 years. Any rumor that a new upgrade or sidegrade version is coming soon?
Don't you have to send it to the factory for that, and they change out the A1 board if you have it, do they not?No.
The Unison blows away the previous USB cards making the USB sound as good as the other inputs.
It’s that good.
No reason to stick to Gen5
Huh…Don't you have to send it to the factory for that, and they change out the A1 board if you have it, do they not?
Could be an urban legend but for almost 7 years now had an A1 which I put the Gen 5 in myself about 4-5 years back. Nobody touches my Gumby.
I could be wrong, but as far as I know, changing the analog board is part of the $500 Multibit upgrade, so I don't think they would be giving that away free while doing the $200 Unison upgrade. I recently had my A1 Gumby upgraded to Unison, and am very happy with the results. Yes, you do have to send it into the factory to have the Unison upgrade performed.Don't you have to send it to the factory for that, and they change out the A1 board if you have it, do they not?
Funny.Huh…
That’s your choice of course.
Schiit “touched” it plenty when they built the thing in the first place the first place.
I guess I don’t see the issue to reward yourself with much better performance.
They basically re-programmed the motherboard if you read the information on the website.
One of those urban legends that seems a lot better seven years ago then today…
