I'll need to try a few other tracks. I used to upsample everything on the streamer to 96K so the GMB may have gotten lazy about figuring out the sample rates itself
I would also try different inputs just to narrow down the possibilities. If you have to contact Schiit they will probably ask anyway. I would also try cycling the power.
Does anyone know how Gumby compares to Denafrips Venus? I've been eyeing that one as a possible upgrade. From what I've been reading, Venus sounds like it could be a major step up.
I own a Bifrost 2 and a fairly new Gungnir and I prefer the Gungnir to the Yggdrasil but I have a hard time saying I like the Bifrost better than the Gungnir. It is very different sounding, and I like it more with some music and the Gungnir more with other songs. I am using the Bifrost with a Lyr 3 and the Gungnir with the Mjolnir so I need to A/B them more with the same amps to do a more serious comparison.
Thanks to you both. Reason I asked is because I replaced my active preamp with a passive and I can measure the high frequency loss.
If I can run the long cable from my GMB to the passive and get rid of that effect it would make me happier. Plus the extra exercise to adjust the volume
Isn’t BNC like single ended AES with 75ohm impedance to run 1v. I guess BNC can also take long distance signal. It’s the RCA SPDIF that can struggle.
please correct me if I’m wrong.
That sounds correct, much of it is about distance and signal loss. It’s been awhile since I studied this. I run RCA SPDIF around maybe 20 feet right now with quality Belden cable. I would use the same for BNC.
