TJ Max
- Feb 27, 2008
What's the clock light doing?
It's not lit.
My guess is it is trying to lock onto a sampling rate, and the CD player is sending either nothing or garbage when in pause so the Gungnir does not know what sample rate to use. My advice is don't use pause.
Don't use pause!? Um well it is what it is, but shouldn't. I have far cheaper DACs that have no issues with pausing with this same CD player. Not something expected from a $1250 piece of equipment. I'd rather route the audio to my receiver rather than just not pause it.
My Gungnir does the same thing with Linn Genki CD player. As suggested below, the Gungnir is either not getting a signal to lock to, or it's getting garbage. This will NOT damage the Gungnir, but it makes pausing CD's an aurally painful endeavor.
Yeah I tried another coax cable and I also tried it with a toslink optical. same same issue. I wonder of the Schiit dacs are firmware upgradeable.
Update: ok this is documented on Schiit's website already,
Clicking When Changing Sample Rates/Pausing/Etc.
1. It’s totally normal for our Bifrost and Gungnir DACs to click (mechanically, from the chassis) during normal operation. That’s the muting relay, doing its job. It clicks whenever the SPDIF datastream is interrupted.
2. If it’s clicking excessively on a Mac or PC, you can reduce it by routing system sounds to the speaker on a Mac, rather than to the Schiit USB Audio Device output. On a PC, you can set system sounds to "no sounds." In both cases, using USB largely eliminates it.
3. If it’s clicking excessively on a CD transport when in pause, the CD transport has a cycling interruption in the datastream. There’s no real fix for this, except getting another CD transport. It won’t hurt the Bifrost or Gungnir, though—the relays are rated for several million cycles.
So basically they want me to buy a new CD player. So how does one know if a CD player has a cycling interruption in the data stream before they buy it?
