lukeap69
- Feb 15, 2014
Some amps short the inputs that aren't being used, either when switched off or another input is selected while switched on. The purpose is to stop the input interfering with the signals while a different input is selected. I found this out the hard way with an Audio-gd amp which I had to remove internal jumpers on to prevent the same thing happening with my Yggdrasil.
Thanks for the info Amos! That explains it. The LC has both SE & Balanced inputs. The PIBE has only one set of SE input.
