winders
Question : Will a noisy tube show up more in the gain or the output stage? Or is doesn't matter.
Gain.....
It makes sense , thanks for your reply.Gain.....
I bought mine from www.thetubecenter.com, but they don't have them anymore. Search for "8 pin socket saver". You do not want just sockets. Make sure they look like this:
http://www.partsconnexion.com/socket_saver.html .
Enlarge the picture and you will see that socket savers have small slots on both sides of the pin hole. It makes it much easier to insert and remove the tubes.
Are there any significant differences between the ones sold over @ Ebay from Hong Kong/Chinese vendors and U.S/CAD online stores? They all look the same, judging by the photos. Probably all made in China?
Regards
The plate voltage on Feya is too high for the small tubes. The nine pin tubes will arc.Would the Saga be a more compatible option (vs. Freya) if attempting to use a ECC88 (6922) tube with a ECC88 to 6SN7 adapter?
Thanks!
Apparently it is theoretically possible in Saga but the mu values are quite different and will probably sound quite poorly. I saw no reason to try it myself.
Edit and Shameless Plug: You may want to read the Saga Tube rolling Thread
If you are wanting to add the 'tube' sound I would consider a tube buffer instead. Two components with gain will be tricky to control.Thoughts about using the Freya in middle of Yggdrasil and Ragnarok? Will it add tube-coloration that Ragnarok alone does not? Thanks!
Someone may well have other suggestions but I'm simply considering them a permanent part of the pre. They are tight so the only way I believe I would get mine out would be by removing the top (voiding the warranty). I can think of no reason I would want to remove them and if I sell it I'll simply include them in the sale.Whats the best way to remove tube socket savers if you need to? They sure are a tight fit.
Best tubes for the Freya listening strictly to classical music, much with vocals?
Several pairs 6SN7GT TungSol black oval (round) plates, blackglass which I personally like a lot
Several pairs 6SN7W JAN Sylvania blackplate clearglass, black base, heavy top getter which seems to work well in the gain stage for classical music
Several pairs 6SN7GT - VT-231 JAN RCA, blackplate greyglass, I plan on using these mainly on the output stage (left two tubes)
One pair coming of 6SN7GT - VT-231 JAN Sylvania, blackplate clearglass, bottom getter, medium glass
Several pairs Sylvania 6SN7GTA (Chrome Top) which I do not like even in the output stage, although better than the stock tubes
One pair 6H8C phony Russian Military nickel base which does not do a great job even on the output stage
Which tubes would you guys suggest for the gain and output stage? Feel free to suggest other which I have not listed.
I have a GUNGNIR MULTIBIT Dac, Wyred 4 sound ST-500 amp, and upgraded Maggie 1.7 speakers.
Great tip. Thank you.This worked perfectly for me: https://eshop.macsales.com/item/NewerTech/TOOLIPOD/
Had it laying around and it thin enough to slide down the center shaft of the socket saver and start lifting it up from the Freya board. Also less than a $1.
