Ghosthouse
- Apr 6, 2015
Now, THAT's interesting! Because my S/PDIF converter is the Musical Fidelity V-Link 192/24, about which I can only say good things.
Do you hear a difference between the V-Link and the Eitr? I would upgrade to the Eitr solely to get any sonic benefits possible. Otherwise there's little point...
First - you won't get any argument from me about the V-Link. I thought it was a good performing/high value device. Putting it between Aries Mini and Gungnir really made things sound great. I actually bought a second to have a backup spare if the first should go south. This was before I got the Eitr.
It has been a long while since I compared Eitr and V-Link. Seems to me the differences at the time were subtle. BUT, I hasten to add, the V-Link would have had many hours on it (hundreds, probably) whereas the Eitr was new out of the box. Always seems to me that electronics do take some time to settle in and sound their best. I haven't compared recently. The Eitr supports the main listening source (Aries Mini) on the strength of it having the latest Gen 5 USB tech and because I was running a Schiit Gungnir. Did keep the V-Link for converting USB from a MacBook Air (listening to Youtube etc.).
At less than $200, can't hurt to give Eitr a try and find out what YOU hear. You can return it if it doesn't seem any better than the V-Link.
One thing that is definitely worth trying on the V-Link is a double-headed USB cable where signal and power leads are separated. I got one off E-Bay from Douk Mall. Very reasonable price. iFi, Cardas, and others all making double-headed USB cables now.
