davide256
- Aug 13, 2010
most USB cables marketed are just random stabs in the dark trying to find something that works better, easy to waste $100 + The two I have found that are worthwhileThis has probably been asked a million times but does the quality of the USB cable matter with Gen 5? The reason why I ask is because I'm using Optical with my Gumby since the Gen 5 USB sounded hazy and muddy but I was also using a cheap Belkin USB cable. Does Gen 5 USB scale as an input with the quality of the cable? Thanks!
Uptone Audio USPCB - its basically a circuit board connecting the USB plugs,price $35. its disadantage is it is very short, doesn't bend. If you want to stay below $100, you can't do better.
Lush 2 - user configurable shield grounding, but comes already set for expected best configuration. It works very well but costs $239. A favorite at Computer Audiophile
If you want a flexible cable, Wireworld starlight USB isn't bad but the USPCB is better. And yes, ditch the DOA Belkin cable
