Schiit Eitr impression and USB-SPDIF converters discussion
Oct 17, 2018 at 11:36 AM Post #796 of 1,112
The P/S is a linear low-noise unit, but you could replace it with another if you choose. It's 6VAC 1.5A.
Not an area I've seen discussed. Any AC manufacturer options comparable to Paul Hynes or Uptone Audio DC power supplies? The better DC power supplies make clear differences
in dynamics and tone color solidity when used for source components feeding the Eitr. Apparently the 5v USB lead to the Eitr is what powers the USB receiver chip in the Eitr, so that
the PS of the connected USB component directly affects the Eitr.
Oct 17, 2018 at 11:42 AM Post #797 of 1,112
Yes, Mike Moffat has discussed that only the USB receiver is powered from the bus and none of that power is used elsewhere in the circuit. As far as experimenting with an different P/S I have not done so as the linear supplied by Schiit seems to perform great. If you choose to experiment in this way there are several power supply vendors who make 6VAC regulated supplies at various price points. It would be simple enough to buy a couple and try. :)
Oct 17, 2018 at 5:23 PM Post #798 of 1,112
Suffering attention deficit? This thread is about Eitr, and USB/SPDIF converters... lets not go off topic with personal "religious arguments" about cable design principles.
It's related to both, though not specifically to Eitr only, rather to all devices using SPDIF, and yes, certainly including USB/SPDIF converters.
As for 'religious' I don't understand you at all, there's nothing similar here. Here are considerations related to SPDIF and reflections:
https://positive-feedback.com/Issue14/spdif.htm
The rest is theory based on scientific (Eddy currents, material conductivity etc.), but also empirical, listening experience related to various RCA connectors (cable lengths also).
Oct 17, 2018 at 8:58 PM Post #799 of 1,112
mm, perhaps + BNC ... I really wouldn't have bought the Eitr if it meant buying a different high cost coax cable.
I hear you... Options are a wonderful thing to have. Still, for the record, clipping off an RCA and crimping a fresh BNC is a trivial matter.
Oct 20, 2018 at 5:39 AM Post #800 of 1,112
Thanks for the info.
My Eitr started acting up with dropouts about every 20 seconds. No amount of rebooting or cable changes would clear it. After emailing to Nick at Schiit Tech Support, back to Schiit it goes. Asked for a refund and will wait for release of the self install Gen 5.
I'm also experiencing dropouts every 20 seconds with my eitr, it's pretty jarring. Has anyone else also experienced this and know a fix?
A few details:
  • I'm using Schiit's own PYST usb and PSYT RCA cables to hookup my eitr -> mimby -> lyr 3 -> eikon. The cables are brand new.
  • I'm using a BlueJeans coax SPDIF, 2ft.
  • I purchased all of the Schiit above this week, brand new.
  • I'm using a i5 2017 iMac running the latest version of OSX Mojave.
  • The dropouts occur when listening using Audirvana, Tidal, and Spotify, with all other programs closed.
  • Dropouts stop on all software when I go direct to the mimby, without the eitr.
Thought I'd ask here first before emailing Schiit directly (esp. since it's the weekend and their customer service doesn't open until Monday anyways). Any advice would be appreciated. Thanks guys.
Oct 20, 2018 at 9:43 AM Post #801 of 1,112
A few details:
Just some general thoughts
1) if your heat has kicked in, you may have static electricity issues. Make sure you have decent humidity in the room
2) power strip "polluters" are not your friend, disconnect anything on the power strip not required for audio.
3) try a different coax cable
Oct 21, 2018 at 12:00 AM Post #802 of 1,112
Hey davide256, thanks for your reply! No heaters here, but I’ll try disconnecting stuff on the power strip and try another coax cable. I realized my 2ft coax cable might not be long enough to prevent reflections, so I decided to pick up a 1.5m coax and see if it changes anything. I’ll update later if any of the above fixes issues... :)
Oct 21, 2018 at 7:03 PM Post #803 of 1,112
Alright, so update: found out the problem was the 2ft SPDIF coax cable. My guess is it's too short, as when I replaced it with some generic 1.5m (5ft) coax I found on amazon, the dropouts completely stopped. If anyone else having this problem, I'd recommend getting a longer (>1.5m) coaxial cable.
The eitr + mimby + lyr + eikon combination is sounding pretty magical now...
Oct 21, 2018 at 8:33 PM Post #804 of 1,112
Not sure the length of a digital coax cable should matter I'm using a .6 meter and it works just fine..
Oct 21, 2018 at 8:42 PM Post #805 of 1,112
There's an argument that a coax/SPDIF cable shorter than 1.5 meter is out "out of phase" and susceptible to receiver deflections.
I think that's the vague provenance of the discussion above.
It's debatable, btw.
Oct 21, 2018 at 9:23 PM Post #807 of 1,112
Blue Jeans does make very nice cables I own a pair of xlr's I don't know why the length in your case even matters ?? enjoy the fix.
Oct 21, 2018 at 9:50 PM Post #808 of 1,112
Yeah, that’s what I’ve heard! It’s strange to me, but the dropouts fixed after I replaced the cable, so I’m not sure? But yeah, whatever it is, the Eitr sounds great with no hiccups now :)
Oct 22, 2018 at 6:29 PM Post #810 of 1,112
I have a 1-foot BJC (Belden 1694A) cable...no issues.
I'd be curious to know if your issue is reproducible...does the problem come back if you use the old cable again?
