TEH725
- Nov 10, 2011
BTW, I want to thank Sceleratus for his upgrade instructions. Putting the board in and re-attaching it with the center screws made lining up the LEDs a snap. It didn't take 10 seconds to get them to pop back in the holes.
I did have one additional instruction and that is to make sure when you are taking the center screws out during disassembly that you have some way to support the main board. I kinda held it up with my other hand so it didn't drop.
One question for anyone who has done the upgrade. Was there a small washer on one of the standoffs that you attach the center screws to? When I unscrewed one of the screws, I heard a click and later when I had to board out, I found this small washer. If so, which post does it go to?
Not sure its a critical piece, but I hate when that happens
