- Aug 18, 2007
A quick note here,
I got my HDP and Asgard today, right off the bat I noticed the HDP's headphone amplifier is better in terms of bass depth and pure amount but no by means is the HDP's bass bloated in anyway either.The song I used to do the test was Infected Mushroom - Vicious Delicious. This is through a Grado RS1 and I matched both amplifier's volume by trusting my ears. If I made the Asgard slightly louder, HDP still is more prominent in the bass department. I will give them both more time and hopefully the Asgard can improve in that area.
The right side of the Asgard is indeed hot and I can barely keep my hand on it (borderline so it is hot). Heat wise from greatest to least would be right side,bottom side ,top side, front side, left side then back side. Do not attempt to lift or move the amp around without letting it cool off a bit in its off state, it is that hot. I'm impressed at the build quality, it really looks great and feels extremely solid. The manual says do not use this as a coffee warmer![]()
Nuforce HDP is a DAC/Headphone Amp/Pre-amp with RCA input/output, 3.5mm and digital optical input - $449
Schiit Asgard is well, just an amp - $249
Keep that in mind
Listen again after the Asgard has 40 hours on the clock. And when you compare the two amps again, make sure you are using the same DAC for each, and you must make sure your interconnects are up to snuff.
I'm sure the Asgard can improve with burn-in, but so does the HDP and I suspect the HDP is going to remain in the lead (as in that's my guess, not fact). If the HDP were only an amp I would say it was worth the asking price, and yet you get a nice 24/96/192 DAC and preamp with it as well. (you can feed it USB, S/PDIF and analog to switch between sources, with RCA out and headphone out)
I would use the HDP DAC with both amps for comparison, where you feed the HDP RCA out into the Asgard and can easily switch between the two amps quickly by unplugging headphones and moving to the other amp. And then I'd try another DAC as well, in case people try to say that the HDP preamp might cause the Asgard to suffer in comparison. Also keep in mind headphone synergy with particular amps.
There are many products that can play above their asking price (Travagans Red with OPA627 or AD743, EF2 with Raytheon tubes, HDP, iBasso D4 stock or with topkit), so I'm not saying the Asgard can't do that. But even I am starting to think there is a bit of FOTM going on here with this Schitt (as has been accused of the HDP which I prefer a little over my $800 Micro Stack). But don't worry, if I ever get some Schitt for myself I will be sure to give it good burn-in and a fair listen.
