Br777
- Feb 2, 2010
my asgard came today... fat... sassy.. and... defective...SCHIIT!. explaination and satirical comments that followed in other Schiit thread...
I'm eagerly awaiting your comparison between the Asgard and the HDP!![]()
This thread sounds more FOTM-like by the day.
To pull-back from some of the unrealistic expectations:
I expect the amp to sound (1) congested on the top with a lack of extension (2) loose on the bottom with a lack of definition (3) not very dynamic (4) compressed/busy during tough symphonic passages (Mahler 5); (5) warm through the midrange, but is not very transparent and (6) run out of power more easily than other amps.
I already know this amp runs extremely hot - I guess as hot if not hotter than Dynahi - and cannot be safely left on 24/7
@Cheesebert, you do realize that if you expect to hear those characteristics, you're much more likely to hear them, whether they actually exist or not, right?
Your finger is close, but it probably needs to be brought in for recalibration<---in case it's not obvious, I kid I kid.
My Asgard has been on for about the same amount of time, 2 days playing music at slightly louder than avg volume. Measurement with an infrared thermometer shows 46-53C on the bottom right side which is the hottest part.
The underside of the amp is about 65-75C, based on the time I can hold my finger (trained over the years from OCing processors).
