MatmaN
- Jan 12, 2008
Does anyone use clip+ with PFEs? I was thinking about changing my cowon E2 to sansa as a secondary dap. I don't think it would make a good pair with HJE900, but audeo...? What do you think?
I think I'll pick up one of these for exercising. I've heard nothing but good things.
Now that you mention it, when I first set my Clip+ USB mode to MSC, so I could install Rockbox, Windows flagged 3 corrupt files and supposedly quarantined them via scandisk. Probably should've mentioned that in my original post...![]()
Well, maybe I'll try to hunt down those bad files, eliminate them, and then try again. Or I could just wipe the memory completely and re-copy everything (kind of a pain, but probably worth it so I can give Rockbox a fair chance).
Thanks!
OK, I re-scanned my MicroSD card with Scandisk and allowed it to automatically fix errors. I checked the log and saw a couple of specific song files listed, and I went onto the card and deleted them just to be safe. Now Rockbox is running great. And I like it! It's too soon to say whether it sounds noticeably different from the OF (especially since I haven't tried any equalization or plugins). But once I was able to build a database, I was able to start using the device as I like to. The initially inscrutable menu system has quickly started to become pretty intuitive. Little things on the stock theme, like inclusion of a clock and additional playback info, are much appreciated. So even from my very limited use, I'd say Rockbox is indeed worth it.
Pageygeeza: I did use the installer.
