earerror
- Feb 3, 2010
Both are great, and basically they are the same thing....except for the video playback that comes with the fuze.
Originally Posted by ClieOS /img/forum/go_quote.gif ..... As for how big a difference is b/w LO and PO, you can read some impression from those who did try the LOD for themselves. |
Originally Posted by ClieOS /img/forum/go_quote.gif ..... Better yet, why not just call them snail oil? Makes life much simpler. Ignorance is a bliss. Over and out. |
I have a Clip+ and J3 - to be totally honest on Flat setting the Clip sounds miles better than the Cowon. Not even close. You really need to use the EQ to get a decent sound out of the J3 - then it sounds great.
The Clip+ is a remarkable little DAP, all things considered.
100% agreed......flat settings .........
I have 2 Clips and a Fuze. Flat settings are best.
I've had 2 Clips, 2 Clip+, and 3 Fuzes.....and the Sansa EQ rather sucks, to be frank. But if you Rockbox them, then the EQ can do wonders, if your other gear requires it.
The interior of a fuze lod that I made in the past
