Hello I thought I'd post my observations on the Sansa Clip.
Conclusion First: I really like the Sansa Clip, it beats the iPod hands down, its cheap, easy to use, has a radio and will record. Its great!!! I have owned five of these things now. I just hope Sansa doesn't decide to screw it up more like they did with the Sport.
Discussion:
I am unsure of the model's I've had. So I'll just tell you what they looked like.
I worked in a noisy computer lab and wanted something to drown out the fans, so I went to best buy and bought a 4GB Sansa Clip. It was great. I even used it on the motorcycle to listen to the radio. I never installed Rock box, since 1. The down loader didn't work on my computer just to upgrade the Sansa firm ware to the latest and greatest. I've taken to listening to books most of the time which I download from https://librivox.org/, its all free but old. and 2. I didn't want a small plastic brick, I wanted a music player.
I was done for, the first one I bought simply quit working, but I never read the manual so I didn't know about Resetting (hold the power button down for 20 seconds) the thing until I bought the second one, and it quit after about a month. With last one I had, I could hear a click, when it reset, so I'd just wait for the click.
DISLIKES:
Some of the MP3's I listen to will cause it require a reset multiple times in a day.
I dislike having to reset this thing all the time.
I dislike when It spontaneously decides to "discover my media" even when I haven't added more songs or another memory chip.
I dislike that sometimes when it sorts chapters on books they appear in the menu scrambled.
The dynamic range for the recorder is insufficient for recording school concerts. It works fine in the middle but distorts really loud, while losing really soft music.
I don't need the extra screen size of the Clip+ since I usually don't look at it except when I am choosing a chapter of a book or radio station.
The mode changing button wore out on the second clip after about a year, so it's stuck on Radio now, and I've lost it
I bought another clip when that happened and then I wore it in the rain, even though I dried it out in an oven at 190 degrees F for two hours. It worked for only a few days then became extremely flukey. Won't even reset now.
I bought a Sansa clip sport, didn't like it. The reset button is gone!!! it doesn't record. Not a good version in my humble opinion.
I like that it is small and clips to any thing handy.
I like the original Sansa Clip 4GB since its the smallest physically.
I like that it will take a 16GB memory chip, I know it will take bigger, but it took me a long time to fill 16GB up
