Hawaiibadboy
BANNED
Just a query - I'm using an Oppo HA-1 on my Note 4 running 5.01 and when I connect my Oppo DAC and run Poweramp I am wondering if it's definitely using the DAC and outputting the optimal resolution. With 5.01 it detects the Oppo and outputs as expected however I have no way to 'confirm' it's not downsampling etc. With Lollipop natively supporting USB OTG it should be fine correct?
Honestly there are some apps that claim to go around alsa but UAPP shows you and it won't do **** if it doesn't have an outside DAC because it's designed to not work via alsa and audio finger. I believe Hiby and Neutron and Onkyo can do it and Onkyo shows the file but not a original v.s. current output way like UAPP does...and I think they should all do that by default. If you shell out and get UAPP you will see if the OPPO is taking control because UAPP won't work otherwise.
ONKYO
below
E18 above Cozoy Aegis below
