allbald
- Mar 28, 2009
I am getting a AKG 701 soon and ER-4P. Can anybody comment on how these sound with those? I am torn between getting this for the ER-4P/S or getting a desktop amp for the AKGs.
Originally Posted by allbald /img/forum/go_quote.gif I will be using the iphone or the laptop as source. Which brings me up to next point -- what kind of LOD + DAC (for the iphone for poratble use) and DAC (for the laptop) do you guys recommend. I think for the time being I would prefer not to by both a portable Amp and Desktop so I thought getting a really good portable amp would be a good compromise. |
Originally Posted by GreatDane /img/forum/go_quote.gif So you're planning to buy a portable DAC/amp combo? |
Originally Posted by GreatDane /img/forum/go_quote.gif If using your iPod you don't need a DAC. You would only have access to the analog audio output, hopefully via LOD. The DAC/amp combos have analog input and digital input. The digital input will mostly be USB but brands such as iBasso offer coax and optical input also. For under $300 it seems that the iBasso D10 DAC/amp is top choice. You might have seen this long thread about the D10. |
Originally Posted by GreatDane /img/forum/go_quote.gif The two 9 volt batteries will cost another $22 or more plus a charger. The advantage with the SR-71A would be more voltage equaling more driving power...not needed with IEMs but would be desired for many full size cans. I hope to do my own P-51/ SR-71A comparisons soon if my wallet allows. I think you're right about which is better. It will depend on your specific needs(which monitor/s) and sound signature preference. |
Originally Posted by GreatDane /img/forum/go_quote.gif I also like a somewhat bright sound...and plenty of bass. I guess i want it all. ![]() So the question is: Can these amps drive the 701/702 to a satisfying level? Well, I've only listened to friends 701 and never with portable amps. With not enough experience I will only guess that HD 650 is more demanding and the P-51 does a fine job at low to medium volume...it almost gets there but falls short with bass heavy music at higher(approaching unsafe) listening volume. With my Woo Audio 3 tube amp my ears beg for mercy long before the amp gives out. |
Originally Posted by allbald /img/forum/go_quote.gif I will be using the iphone or the laptop as source. Which brings me up to next point -- what kind of LOD + DAC (for the iphone for poratble use) and DAC (for the laptop) do you guys recommend. |
Originally Posted by allbald /img/forum/go_quote.gif I am going through a lot portable gear changes ( as in I need to start over ). So assuming I get the P-51 and am using it to drive the 702s from a laptop -- what DAC and cables are recommended from a laptop? I think when the new iphone comes out -- i'll probably get the ALO cryo 18g stuff from iphone to amp but need to understand better what would be good from a laptop as well including cables? |
