LCMusicLover
Same here, although I also use the 2.5mm balanced output.That’s how I used it. Hugo 2 with 3.5mm to BX2-Plus driving my headphones via 4.4mm balanced.
I just received the new 2021 Bluesound Node. My use case is purely for Radio Paradise MQA streams. Have three of them on presets. Using IEMs and headphones via the 3.5mm port on the front. Headphones output to a Romi amp (3.5 to 3.5) and amp output via 4.4mm balanced to headphones (Focal Radiance and HD820. So far quite please with sound quality. Will be upgrading ethernet and 3.5mm patch cable next week.Many thanks for the verification.
Probably my imagination but it seems to me the 2.5 mm and 4.4 mm balanced outputs sound slightly different. Anyone else notice that or should I just check myself in for a mental evaluation?Same here, although I also use the 2.5mm balanced output.
tl;dr I don’t hear a meaningful differenceProbably my imagination but it seems to me the 2.5 mm and 4.4 mm balanced outputs sound slightly different. Anyone else notice that or should I just check myself in for a mental evaluation?
I also agree with this..tl;dr I don’t hear a meaningful difference
I’m comparing w/ this chain:
dx-200 (coax out) ==> Hugo2 (3.5mm SE out) ==> BX2+ ==> HEKse (2.5mm terminated Lavricables Grand w/ Cayin 2.5-to-4.4 adapter)
Overall, I would say ‘I-dent-ical!’
On a few tunes I thought maybe I heard a little wider headstage from 4.4 out, but could never hear it consistently enough to be sure it wasn’t just an artifact of switching, and I actually thought I heard it the other way a couple times.
Other than that, I heard no difference.
I also tried w/ Utopia and Auteur from the same chain with the same results.
At first I thought this picture showed two BX-2's side by side. Being used as a monoblocks? What the.....? Closer look and now it makes senseI also agree with this..
a side u believed in burn in or not, but solder also need time to break, how long the break in.. I also dunno.. but just enjoy the ride..
Have not found a heat problem with the case when indoors usage.When I purchased my BX-2+ I also purchase the leather case. Up till now the case is still in the package it came in. It seems with the case on that the amp would run even hotter than it already does. Of course when I'm carrying it with me it would shield me from the heat. Just want to verify it can't run so hot as to be dangerous to its longevity. Opinions please?
I have had amps kick in their heat protection before, but never BX-2+.Have not found a heat problem with the case when indoors usage.
I never have experienced any extreme heat coming from the BX2+ with the case. It runs a bit hot, yes, but it's normal. My now sold Phatlab Chimera, without any case, ran hotter (because of the tubes obviously).When I purchased my BX-2+ I also purchase the leather case. Up till now the case is still in the package it came in. It seems with the case on that the amp would run even hotter than it already does. Of course when I'm carrying it with me it would shield me from the heat. Just want to verify it can't run so hot as to be dangerous to its longevity. Opinions please?
I didn't know this amp had a temperature protection built in. So it would just shut down if it overheated?I have had amps kick in their heat protection before, but never BX-2+.
I just assumed that, honestly don't know. But Hugo 2 for example shuts down when over heated.I didn't know this amp had a temperature protection built in. So it would just shut down if it overheated?
Maybe I will send them an email and ask. I do use mine outside and if it's an 85 to 90° day already, plus it's in a waist pouch (do people still call them fanny packs?) and then the sun comes down on it a bit sure it's getting pretty hot. Even without the leather caseI just assumed that, honestly don't know. But Hugo 2 for example shuts down when over heated.
