NoValidTitle
- Mar 4, 2007
Anyone able to provide the full height of the shielded/encapsulated SumR tranny?
Originally Posted by amb /img/forum/go_quote.gif Try reversing the left and right cable hookups from your source. Does the problem stay on the same side or does it switch sides too? If the latter than the source or cable is the problem. If it stays on the same side, then inspect your wiring very carefully to make sure it's all correct. Is the hiss affected by the volume control? Does it hiss when the volume is turned full-off? |
Originally Posted by zare /img/forum/go_quote.gif That is true, but by also depends if you are using 50Hz equipment on 60Hz line or the other way. 60Hz transformer on 50Hz line will make 17-20% V increase. In some cases that can make transformer cores saturated in the no load scenario. Well, I'll check the papers that came with the transformers and get that clarified. |
Originally Posted by Beefy /img/forum/go_quote.gif Awesome For the benefit of others watching this, my dilemma is that I am in Canada now so would ideally have a transformer for 115V at 60Hz. But I will want to take my gear back to Australia with me in a couple of years time, so will want these transformers to also run at 230V 50Hz. It is my understanding that 2 x 115V primaries designed to run at 50Hz is the best semi-universal solution, without the transformer getting really huge and having a stupid number of taps on the primary. But for an investment like this, I want to get it right! |
Originally Posted by Hayduke /img/forum/go_quote.gif I don't know how much it would cost or if it's available, but can you get a single transformer that has multiple sets of wires coming out? ie you connect it to the boards for 115v here and switch it to 250v when you get down under. |
Originally Posted by smeggy /img/forum/go_quote.gif Ok, finally we have a working Beta 22!!! Thanks to everyone for their time, patience, generosity and knowledge, without all the help I received I would never have this working, and working gloriously I might add. Holy crap this is good. Thank you all. |
