FallenAngel
One post helps and even better, use the dedicated Beta22 build thread for this.
1) Balanced = 4 boards
2) I can send you my modified FPE files if you want, but remember, you'll still need to make sure you get the holes cut for the connectors YOU intend to use (unless you want to duplicate mine
3) Output uses Neutrik 1/4" / 3-pin XLR combo jacks, have fun wiring, no adapter needed.
4) Not too many balanced diy DACs (or DIY DACs in general), you can either buy commercial, look on ebay for kits or wait for next buffalo batch. If you want pre-built, I'll be selling my Buffalo24 DAC soon.
