amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
A balanced β22 will comfortably give you 50W+ of power into 8Ω (provided that the PSU is sized appropriately), but it wasn't designed to do so in a sustained manner. The TO-220 MOSFETs' thermal resistance is not low enough, even if you use big heatsinks, to run at high output continuously without risk of overheating (and this applies to both the amp and the σ22 PSU). Obviously, what defines "high output" vary depending on the efficiency of the speakers and the size and acoustics of the room. For most moderately-sized rooms and relatively efficient speakers, and with enough heatsinking, and reasonable playback volumes with occasional high peaks, it should be fine. Just don't have any expectations that this amp would be able to serve as a pro-grade PA or concert amp!
The β24 on the other hand, is designed from the outset to be a speaker power amp, with larger TO-247 output MOSFETs and large heatsinks. Also, in the β24, the σ22 PSU provides power to everything except the output stage, so it's relieved of the high-current and high power dissipation burden that's present in the β22. Thus, β24 would be much more adept at high sustained outputs.
Originally Posted by FallenAngel /img/forum/go_quote.gif is there any reason NOT to use a balanced Beta22 for speakers as a 50 Watt amp? |
