el_matt0
- Feb 7, 2007
yea i have done that! i may have missed something of course, but like i said, none of the components were changed so i doubt its a cold-solder on one of the boards. and i was pretty anal with the wiring this time around! ive narrowed down the symptoms of the problem a bit. so again, like i said earlier, once the problems kick up, if i turn it off, wait a few minutes, then power up, the biasing was a bit off across R34, so i adjusted it as close as i could get em all to 75mV. plug my headphones back in and start listening, sounds GOOD, everything sounds like its working, no obvious problems at all, and i can listen indefinitely at these lower volumes. the measurement across R34 wobbles around a bit ranging from 60-90 mV or so (dont know if thats normal or not). and when i plug in a pair of S.E. headphones to one of the single ended jacks powered by the L+ and L- (for L and R respectively) , the R34 value on my L+ and L- boards jumps up to around 120 mV or so. it returns back to 75ish once the S.E headphones are removed, so i assume this is normal!
so basically, when i increase the volume to higher listening levels on my balanced cans, i hear buzzing start at some point and then the left channel basically cuts in and out even once the volume is reduced (and it OBVIOUSLY doesnt sound good). problems gone upon power down, and quick re-bias. explanations / solutions?
