Roll Call: Who's building, built, or thinking of building a beta22?
Jul 26, 2013 at 10:26 AM Post #2,986 of 3,218
Where can I find a beta22 builder? Need a 2.0 ch with metal chassis. Ready to use. Budget $500 or less. Can anybody help?
Jul 26, 2013 at 10:30 AM Post #2,987 of 3,218
I can help by telling you to stop dreaming. Those are *ridiculous* expectations.
Jul 26, 2013 at 10:52 AM Post #2,988 of 3,218
How is it ridiculous? All parts with a chassis cost barely $350. What is the minimum amount of service charge? How much? Isn't $150 okay for a couple of hours?
Jul 26, 2013 at 11:28 AM Post #2,990 of 3,218
a couple of hours?
first: to populate the boards, is a hard work.
second: calibrate the boars
third:hole the chassis, wiring, etc.
fourth: 350 dollars waht components?
the beta deserve good quality
Jul 26, 2013 at 12:22 PM Post #2,991 of 3,218
putting together a BOM and ordering parts is more than 2hrs, much less building the amp.
Jul 26, 2013 at 1:09 PM Post #2,992 of 3,218
If you are happy with a B22 thrown together in a couple of hours, go right ahead.
Hint: you shouldn't be happy with that.
Jul 26, 2013 at 1:17 PM Post #2,993 of 3,218
Is it even possible to assemble an entire B22 in a few hours? Fastest I've heard is 5. That builder (that is able to assemble in 2 hours), whoever they are, is Dr. Octo.
Jul 26, 2013 at 1:41 PM Post #2,994 of 3,218
no way.  sure, stuffing a single O22 and 2x B22 boards in 5hrs, but not chassis work, wiring, biasing and testing.  stuffing boards is the easy part.
Aug 1, 2013 at 4:31 AM Post #2,997 of 3,218
Yea, I don't think that was taking into account casework - I mean I've been working on my case for 2 weeks... lol.
2 weeks? I've been planning my case work (drilling, board orientation and measurements) in my b22 enclosures for almost a year lol. Need to buy a drill press.
anyone still building their own b22? or looking to build b22?
Wow, lurking since 2011 with the first post to see who is still building a b22. Welcome to the boards, friend.
Aug 1, 2013 at 4:34 AM Post #2,998 of 3,218
A good drill press does make the job a lot swifter and easier. :D
The planning didn't take to long. The troubleshooting has taken the longest. :mad:
Aug 1, 2013 at 4:40 AM Post #2,999 of 3,218
Indeed, it is even if one had a steady hand, a hand drill is no match to the precision from that of a drill press. Wish I had my own CNC and engraving machine too, I've contacted a few local suppliers here to get quotes on engraving and milling work to be done on my b22 enclosures, suffice to say it is not cheap, price is about the same as a single b22 board with BOM parts from Glas Jar Audio at $100 a pop.
+1 on troubleshooting, a major headache of any diy process if you run into problems, but you learn a great deal about things once you rectify your mistakes.
Aug 1, 2013 at 8:24 AM Post #3,000 of 3,218
It's been a long while!! :) I actually got my parts for quite some time... But the enclosure is putting me off for a long while... Haha hopefully I'm able to get some ideas here for my enclosure.
