Alick
- Apr 24, 2003
Nice cases and even nicer prices. Thanks.
Originally Posted by el_matt0 /img/forum/go_quote.gif what would be the case for XLR connectors? http://www.takefiveaudio.com/mall/shopexd.asp?id=368 those are the ones im planning to use. i cant seem to digup info on whether the signal is isolated or not in those |
Originally Posted by n_maher /img/forum/go_quote.gif MrMajestic2, I guess you're somewhat lucky that your shipping for the cases will only be € 30,00, for those of us in the US we're looking at more than double that amount. It makes using those chassis simply not an option which is a shame. |
Originally Posted by el_matt0 /img/forum/go_quote.gif ALRIGHT, in BUSINESS! swapped Q1 and Q2 on my "problem board", and bingo, 0 mV dc offset. i can get it down to a steady +/-0.2-0.3mV for all 4 boards, is that within acceptable limits? what is considered "dangerous"? sounds DAMN great on my balanced 650s so fAR!!! one problem, it seems i wired my potentiometer backwards! im using an alps quad pot and i wired it as shown on AMBs site, with the axle facing towards you, all 12 lugs upwards, i have my grounds on the left, middle is going TO the boards, and the right is coming from the inputs. problem is counterclockwise all the way is MAX, and clockwise all the way is off or minimum! obviously ive just gotten something totally backwards, which do i need to swap?? leave the ground and swap the other two so that the "right" side lugs are all going to my boards? |
Originally Posted by el_matt0 /img/forum/go_quote.gif ah ok, so my middle ones are fine, but my ground and wires coming from inputs need to be flipped? |
Originally Posted by el_matt0 /img/forum/go_quote.gif @ mr majestic. took me longer than expected to get mine going, but maaaan it was worth it!! ![]() ![]() |
Originally Posted by MisterX /img/forum/go_quote.gif Does that mean you are going to build one Ed? ![]() |
