@Musikfan
Okay, so here is a picture of the internals of the RH-5 that I took one of the times I had it opened up.
Please note this is an educated guess.
If you follow the flow of energy from the mains you will see the fuse just below the two stacked toroidal transformers. Below that you can see the fuse. My GUESS is that the side of the fuse that is closer to the mains and power supply is the power side. The other end of the fuse takes the power off further into the amp. For lack of knowing the correct terms, I'll just call this the "power side"(closer to the mains) and the "amp side"(closer to the amplifier side).
You can always send Rogue Audio an email to confirm. I don't think it really matters but then again maybe it does.
