AND, the different set of files in the .roxbox folder can be a custom setup for just those files on that card.
You are right. Thanks for pointing it out! My personal settings are stored on the card as well. This could be considered useful by some. However, it raises the question how to keep all cards consistent, in case you're like me and don't want different custom setups on your cards. Let's say I change an EQ setting for a certain headphone or IEM. The next thing I'd have to do is apply the same change to all the other cards, because I don't want the sound to change on swapping cards. This is just not how it works with all other devices (namely my collection of clip zips). More importantly, I have to check the volume setting after swapping cards, because I might have used a card with relatively insensitive full-size headphones (think 600 ohms T1) last time. If I'm currently using sensitive IEMs, a simple card swap can be hazardous to my hearing and/or IEMs.
There are probably reasons why it's implemented this way. I'll just keep using only the second slot for music and everything's fine!
Did I mention that this player drives my T1 with ease? It does!
