mbwilson111
- Oct 13, 2016
Aah...so you don't need gigs and gigs of space for Rockbox...gotcha...You all really know what's up..thanks much
I have read the entire thread
Obviously. So great. I didn't get a response for a couple days, so wasn't sure how active this forum would be, but the response has been terriific. I still haven't gotten it yet, but when I do. I feel like i've got plenty of 'real life' experience to call upon. Thanks so much to you all.
A handy effect of having rockbox running from the card that has the audio files on it is that the rockbox settings can be different for different cards or sets of files ( I use smaller cards with different sets of files on them ). By switching cardsm it easy to switch to a completely different tockbox environment.
An example of what I mean is that I have a card full of old albums from the 60s that are uncomfortable to listen to with earphones because they are 'mixed' with extreme left right pan positions due to the way they were recorded using very few recording tracks. Some Beatles albums, for example. The rockbox settings on that card include a severe narrowing of the stereo width of the mix.
I might be a bit unusual in that I don't like wide panning of artificially stereo music if I'm listening to it with headphones or earphones. On the other hand, I do love the lush stereo width of modern recording techniques and effects.
In the past, music was mixed and mastered to make 2 wooden boxes spaced several feet apart sound as exciting as possible. With earphones, those mixes are too exteme, usually. Well, that are for my ears and taste.
Now I've properly formatted a 64gb card (via guiformat.exe) and eased it into slot 2, but since then I notice that an addition to the opening menu has appeared, I now see <microSD1
Ok so your player is seeing both cards but your PC is not. If I connect my player to the PC I get a drive letter assigned to each. I wonder why yours is not doing that. What happens if you put that card into a card reader?
I am also using windows 7
that new <microSD1 is that second card in the player
the first card is just treated as if it were part of the player I guess... it is a bit weird
my first card just shows as MUSIC because all my albums are in a folder called MUSIC
Thanks 'Wilson.
I'm not sure if what's reporting as <microSD1> is really the second card or not. It's possible, so perhaps that's why you say that the X3 is seeing both cards. (Below the extra card item, the rest of my content is showing as normal. I have it organized more or less as separate folders by genera.)
I don't see two Removable Drives when connected to the PC. When I use a card reader with the new 64gb card it assigns a Drive letter and shows empty.
FWIW, this didn't just happen today. I added the second SD card a couple weeks ago... just now getting around to addressing this.
Again, thanks.
The <microSD1> designation is a leftover from Rockbox being ported to players with internal storage and MicroSD expansion. Rockbox was always installed on internal storage, so external was considered <microSD1>, but since the X3 has no internal storage, Rockbox considers the card it's installed on as internal, and the card it's not as that external card. It's confusing, to be sure.
