rikk009
- Apr 30, 2014
Yes you are right it looks like a double sided tape. Will try with a hair drier. I have checked the connections. Last I checked I could hear pop sound on button press. So it's the display at fault.Well, the screen is broke anyways, so you can't make it any worse haha.
Are you sure it's super glue, or could it just be double sided tape? Could also be heat glue (that could be loosened with hair dryer or heat gun (on low heat).
Did you check for obvious problems, like a cold solder joint, torn or damaged ribbon cable, bad SMD component etc? It may not be the screen at all, but rather something on the circuit board that drives the screen.
