- Dec 30, 2013
Not experiencing any sound glitches or dropouts using AAC files napka
I'm sick right now, so I probably wasn't remembering correctly.
Originally Posted by uli87 /img/forum/go_quote.gif
I installed a theme pack and currently I found that from all themes "cabbiebasso" is to my liking.
Not all of the album art appears. I think I noticed a pattern that only ones embedded into the files work? Most of my cover art are just jpg added to the folder.
Look for the first matching album art bitmap in the following list:
./<trackname><size>.{jpeg,jpg,bmp}
./<albumname><size>.{jpeg,jpg,bmp}
./cover<size>.bmp
../<albumname><size>.{jpeg,jpg,bmp}
../cover<size>.{jpeg,jpg,bmp}
ROCKBOX_DIR/albumart/<artist>-<albumname><size>.{jpeg,jpg,bmp}
<size> is the value of the size_string parameter, <trackname> and
<albumname> are read from the ID3 metadata.
If a matching bitmap is found, its filename is stored in buf.
Return value is true if a bitmap was found, false otherwise.
If the first symbol in size_string is a colon (e.g. ":100x100")
then the colon is skipped ("100x100" will be used) and the track
specific image (./<trackname><size>.bmp) is tried last instead of first.
Where did you find this theme??
I embed covers and put cover.jpg to album folder. It brings me covers in all hardware and software players I use.
Here's comment from related rockbox source code:
Just thinking how long it will take to embed everything... -_-
btw, do you know why some files have a tiny glitch with gapless?
These files were downloaded. I found a different download of the same files from a different uploader that play perfectly. Rockbox does gapless as long as the files don't have cut offs for any reason.
