all999
Hi, I just uploaded another build. Can anyone help test it the crackling issue is reduced or not on this build. Thanks
Rockbox_DX90_0_0_6_beta.zip
Crackling issue is gone, thank you.
Sorry, it's still there
with 006 beta build it looks the cracking noise is gone
Will be installing 0.0.6b to test whether the crackling noise have been resolved. Liking your great work until now!
Ive been listening to this version for a couple of hours,can still hear some crackle,however it does seem to be a lot less frequent in showing up but when it does,its not as loud and doesn't seem to last as long as previous rockbox version.. It may prove difficult to completely eliminate the noise,personally I can live with with it,so thanks to you guys for all your work..
How does it compare from the previous build?
Thank you all for testing. I think I found the source of the issue. It looks like the buffer size. I am playing with different buffer size and I think I hit the right balance. The CPU performance boost also helps.
Still having slight crackling issue - but not much compared to 0.0.3. Only once through a couple hours of listening, where I got more around 2-3 times per half hour on 0.0.3.
Yes, buffer size might actually be root of the issue, seems plausible. Can't give feedback compared to 0.0.5 as I wasn't around that build.
Also - random thought. Reckon that the CPU temperature will be affected by the performance boost, might not prove to be a current issue, but over time it might decrease lifetime?
Is there anyway to revert back to the Mango firmware without the dual boot option? I'm not really as big of a fan of Rockbox as I was on the iPod Classic. Navigating Rockbox on the DX90 seems rather cumbersome to me and I would rather prefer to use Mango's intuitive UI. Sorry, I guess Rockbox isn't for me.
Here's the latest build. I listened the whole day and didn't notice any crackling noise anymore. Let me know if you still hear any crackling noise.
Rockbox_DX90_0_0_8.zip
EDIT: I added Lurker0's int V2 mod on this build.
EDIT: I added Lurker0's int V2 mod on this build. :etysmile:
