dafos58
Still no luck. Same error message: "Temporary error, retrying."
Me too, I've got the same problem, even with add ons and extensions disabled. , is there any other link available?
How is the coax output with Rockbox? Does it work okay?
Great news, indeed! I never wanted to put Rockbox on my Cowon players because the builds seemed unstable.
Nobody has mentioned it yet, but I can test it tonight on my desktop setup. I suspect that being an uncommon hardware feature for most players that use the Android base, so it may require some additional implementation?
Thanks, will give it a try.
Guys for all who tested rockbox..
Can i get your impression for the sq diff between rockbox 1.2.8 ?
I have been testing the whole day may be more than 30 songs, by switching between both players.
I listen to rockbox eq off then change to mango directly and listen to same song, i feel its better on 1.2.8, i feel it got wider sound stage and better details, problem is when i switch back to rockbox again, i feel no difference hahahaha
So it seems i went crazy or something, anyway its good to hear others impressions.
Also a tip, when a folder contains too many flacs on rockbox, the scroll isnt smooth and a bit slugish, i increased the scroll width from the theme settings, and used the fat scroll to go down and up, its much easier and faster.
My quick impression so far is Rockbox at default(all settings at 0dB) the response is ruler flat. I makes the orig FW a bit colored especially on the lows. If you like that you still can do so in Rockbox by tinkering on the EQ. I have not done a critical comparison yet. Just trying to listen to as much music with Rockbox first.
I don't know if I notice any change in soundstage, but I thought Rockbox appears to resolve more details especially the micro details, which is more obvious on a few classical songs I listened to so far.
does anybody else get the following error when trying to play from database?
*Panic*
Stkov audio
pc:0068554 sp:01502a4
A: 000685bc
bt end
I'd be grateful for any suggestions.
This is what I want, because I'm coaxing into a pretty good Dac and then into a Lyr with good vintage tubes. Starting with a colored source causes me all sorts of problems.
