dlayman
- Oct 23, 2015
That is surprising. When I had to return something, they responded the same day. I would contact them again. Maybe something got lost in cyberspace.
Would the Chord Mojo be overkill as a source/amp for RHA T20?
Tempted to wait for the RHA DACAMP (January?), but need a new source for work since my old Fiio E07K sounds pretty terrible with my new T20s compared to all my other sources.
Andrew.
Probably, although I'm sure it would give you excellent sound. The T20 is pretty easy to drive, despite its specifications, and I've found it to pair well with everything I've used it with. My sources aren't nearly at the level of yours, Sansa Clip and Samsung Pro Tab.
I also have a pair of Sennheiser Amperior's which I really enjoy!
Then you will love the T20.
I have them both, T20 and Amperior and to my ears - the T20 are even better.
Cheers,
K
That is great to hear! I didn't expect that at all, but awesome!
There are so many mixed reviews of both the T20's and IE80's that it is hard to comb through all the meaningful info. The fact the IE80's have a ton of problems with a good seal definitely worries me. And there are many reviews on the T20's that say the low end is not great as well.
I'm looking for a meaningful upgrade to my Klipsch's that can withstand gentle every day use and the occasional stage monitor use. I am I drummer once in a while so a decent isolation would be nice. My ears would appreciate that! The reason these 2 are at the top of my list is because they are made for around the ear, which a much prefer. If there is anything else out there in the ~$225-250 range, I'm all ears....
Thanks in advance for any help!
Mark
Hello all, I've been looking at the RHA T20's vs the Sennheiser IE80's for a while now and I'm more confused than ever. I know the IE80's are on sale right now for the same price as the T20's which is a good deal. But, I'm having trouble sorting out all the facts. I listen to all types of music, but mostly from my iPhone or Android. I listen to top 40, country, rock, classical, vocal, but not EDM, trance, metal, etc... For the past 3 years, I've been using Klipsch S4's. They don't get very many great reviews, but I've enjoyed them. Mine don't seem to have the harshness in the treble that Klipsch can have. I also have a pair of Sennheiser Amperior's which I really enjoy!
Mark
