VirtualOne
- Feb 14, 2012
I also have the volume quite low, definitely lower than 9 o'clock. Probably around 8 (can't look right now since I'm not at home). I don't have other amplifiers yet - this is my first one.
Btw, I'm using USB because on S/PDIF Zero would loudly click (from within its housing, not in the headphones) every time the signal started / stopped. Even worse, after a couple more seconds I would always get a relatively loud pop in headphones, so it was unnerving, every time a song ended to wait for the dreaded pop. The pop was probably caused by the mobo (with built-in Realtek), not Zero.
I tried to connect Zero to other power outlets, guessing it might change the noise, but to no avail. So it's again on my UPS-protected chain.
Anyway, Zero sounds nice otherwise, its just this "shhhhhhhhhhh"... even when the music drowns it, of course it's still there, reducing the total clarity...
One other thing bothers me: when turning Zero on/off the headphones receive a loud pop as well. Hopefully it isn't detrimental to the headphones?
I'm new around here, what would be the best way to ask for recommendations on affordable (sub $500 if possible) dac+amp with a neutral sound and as-quiet-as-possible background? Or at least amp, I can have Zero as a DAC, although it will be a pain to switch two devices all the time.
