I mentioned before that my Zero (from wsz0304) stopped working but I wanted to have you guys weigh in on a possible cause. I currently switched out the DAC board from another Zero that had a bad HP amp so I have a running system, I am just worried that something will happen again. Also, it's been a week since I asked wsz0304 if he will give me a replacement (he had responded earlier about things that his engineers said I should test to verify exactly what isn't working). I have a working unit now (from my own spare parts) so I am not as impatient as I would be if I was sitting here with nothing, I just hope he comes through seeing as how I already gave him feedback so he has 0 incentive to satisfy me. However, I am hopeful and will give it time.
Ok, so the description of the failure:
-It worked for a little over a month.
-Nothing was changed in my setup for quite some time before the failure
-Only mod was upgrading the OPAMP in the HP amp (which still works)
-I left the unit on most of the time, the unit sits on its side and nothing is obstruction the vents.
-The LED's lit indicating signal lock and the relays click when I played a song so it seems that part was functioning
-I tested the OPAMP from the DAC in the other DAC board and it appears to still be functioning
-When I swapped out the DAC board for the one from my other system, everything worked indicating the problem was in the DAC, not in my signal delivery.
Possible issues:
-I left the unit on so anytime Windows would send a sound (error dings, etc.) the relays would engage. Could this cycling of the relays some how damage other components?
-Some I plug my computer speakers into the Zero HP amp for convience. The speakers input is designed to be plugged into a soundcard (1/8 inch plug) so I imagine its not drawing tons of current or anything, it has a build in amp. Is there any way that this could be an issue?
