jujulio
- Apr 19, 2008
that leads me to this question: i intend to buy a little dot mkv after the zero. Is it of any use to use the amp section of the zero if i buy the mkv? Or am i better off turning it off?
Originally Posted by jujulio /img/forum/go_quote.gif that leads me to this question: i intend to buy a little dot mkv after the zero. Is it of any use to use the amp section of the zero if i buy the mkv? Or am i better off turning it off? |
Originally Posted by jamato8 /img/forum/go_quote.gif I checked with the distributor that makes the mini to mini plastic optical cables I use. The bandwidth is a minimum of 38MHz to a max of100MHz. I am wrong. The newest plastic cables have a higher bandwidth than what I stated. I have the white paper if anyone wants it. It would appear there is plenty of bandwidth with the plastic cable I use mini to mini and mini to toslink. |
Originally Posted by jamato8 /img/forum/go_quote.gif Plastic transmission has come a long ways. Bandwidth on what I quoted above has increased 3 fold. I will take the plastic and ability to flex and bend over and over to the more delicate and expensive glass, when the plastic is done right. I get mine out of Canada, they aren't expensive and I can get lengths including the ends of 3.5 inches. |
Originally Posted by jujulio /img/forum/go_quote.gif thanks for the tip dude! i am gonna buy this to connect my audigy 2xz platinum pro to my future zeo |
Originally Posted by les_garten /img/forum/go_quote.gif Mine has a voltage switch and it does not hum. |
Originally Posted by les_garten /img/forum/go_quote.gif The Mk V Blows the Stock Zero's Head amp away in Base Extension and tightness, midrange detail, and everywhere else. Unfair comparison. It's fun going back and forth real easy though. And with the Zero Vol Pot, you can match the levels and go back and forth with little drama to do A-B comparisons. Zero + MK V is a Nice Combo. The Zero Head amp makes a lot of heat though, and long term, I most likely will D/C it. |
