ScottieB
- Jan 13, 2007
Yeah I get why to do it - just need details on HOW - I know it's been illustrated here before, I just don't recall... thanks
Originally Posted by grkn /img/forum/go_quote.gif What do you guys think about doing the Lampizator bypass to the line out and installing a couple of LT1364s for the headphone amp? Wouldn't this be the cost effective route to go? Why bother with HDAMs if you can bypass? Cheers. |
Originally Posted by dacavalcante /img/forum/go_quote.gif Hi guys, I'm wonder if doing that will do any harm on Zero ? The mean reason for this is to try to identify bass loss with 3 HDAMs setup. That way I'll use a flat 40Hz wav and check both at the same time. I already did it swaping both, but really couldn't come to a conclusion.... They seem to produce the same SPL. The other option is to find the spot on the pcb where I can mesure with a voltimeter the head amp section output, that way with a flat 40hz signal, I can check which one got the higher voltage on the output for this frequency. the high voltage will have more bass....... Diego |
