kkl10
- Dec 26, 2010
If anyone is interested I'm selling my D100.
How is this D100 behaving after a while...I was thinking it might be worth the investment, but I also read some negative reviews about its reliability.
New hobby kkl10?
I plan on eventually getting a dedicated amp for the D100 just like you mentioned. It's a solid amp, and an even more solid DAC
RECAP after about 6 mths of use
Well, I had several problems:
-the vol knob came off since it's made of cheap plastic and not a metal one held by a screw
-the unit died, possibly overheated, now all outputs have some sort of static, distortion and humming/buzzing.
-the unit refuses to accept input after I either connected or switched on an external amp (just says 'noinput' and doesn't accept the signal via usb).
-loud clicks in the HP when you switch the unit on/off.
In light of these (especially the breaking part), I've revised the review scores and lowered quality and design to 1.5 and 3 respectively. I hope Audiophile china and/or Mr YuLong help me out and fix it. (getting a replacement unit next week (21st Mar))
edit: got a replacement unit, took about a month. Probably won't be keeping it.
When I turn my unit on with my IEMs or GMP plugged in, there's a very faint, almost inaudible pop regardless of the position of the vol knob.
When I turn it off there a loud crackling noise (as loud as music volume) if the knob is in a higher position than the first three steps (where channel imbalance resides on my unit), but there is no noise if the knob is at these levels. This is not uncommon with amps, though.
EDIT: By the way, USB input glitch issues are not uncommon with USB Dacs. USB input usually require some tweaks on your PC/media player output settings.
