Sorensiim
- Dec 11, 2008
Heatsinks installed
Nicely done
I'm wondering if I should do the same. I'm keeping the D100 in a better and wide open area now so maybe that should help and it does get pretty cool in that part of my room.
Hi, i was really looking forward to buy a Yulong D100 until i read about that quality/overheating backdrop. Now i am not sure anymore, even with heatsinks installed you cannot be sure, can you? I am thinking about opening the Topside Case as well or maybe create venting holes throughout the Topside.
Anyway, these things sound annoying.
Any clues about the Matrix DAC (the other DAC/AMP i am very interested in) has/tends to having similar problems? Anybody around who has used the Matrix for some months extensively?
HM, dang about this heat stuff. My shelf is half closed, and yet there is no solution in sight.
Thanks for pointing out these facts, but i am not totally convinced.
Maybe heatsinks and venting holes could be enough.
I just wanted to say it showed frankly that if something goes wrong with the device, you gotta send it back to china for replacement/repair, which is annoying. I would take it to a guy here in my city, who is a genius in electronic repairs...he does it for a living. I mean he surely could take a look inside, but warranty would then be invalid since it has a sealed case, right?
I know it's all theoretical here, but i just need to be sure on such worst case scenarios
I see, well, maybe i am just too paranoid. It is because i don't trust chinese quality assurance and production standards a priori.
