reprobyte
- May 7, 2014
Is there a list of the headphones that match best with this amp and its SE ports?
I had a V200 and a V281. Could hear hum from the transformer in both when using IEMs. The V281's hum was about twice as loud which is expected considering it is essentially a double V200 with two transformers. They are definitely not the cleanest sounding amps.
Can you recommend me any IEMs for Violectric, which ones are a good match, I have the V220 so can yuo recommend what you use on your V200?
You could use an iFi ieMatch with the Andromeda. I guess the best "match" otherwise would be an IEM with low sensitivity? I don't have any low enough where I couldn't hear the hum without the ieMatch.
$1200,- seems a bit much if you ask me..and I loved this amp, shame..
922 € in Europe. Had it on my wishlist at Thomann for a while hoping for a price decrease, but it never did and I bought something else.
$1200 is a lot for an amp with audible transformer hum and a resale price around $400.
I wonder why you seem to be the only one dealing with this humming and noise issue ?I had a V200 and a V281. Could hear hum from the transformer in both when using IEMs. The V281's hum was about twice as loud which is expected considering it is essentially a double V200 with two transformers. They are definitely not the cleanest sounding amps.
