V200 made some changes during production.
The first items had a nextel coated front panel - dark grey.
Also there was a volume knob with a white line.
The front panel changed to be black anodized.
The volume knob changed to be our own design with a slotted marker.
The volume potentiometer itself was, is and will be the RK27 from Alps.
But the first items had no detent, since about 2 years they have a 41-detent which is a nice feature to exactly reproduce a specific volume setting.
But it is still a potentiometer, no switch, because those switches only have 12 up to 24 positions which is not enough for a gain control.
So you can also position your desired volume between two detents if 41 positions are not enough.
Since last year the front panel from V200 was slightly altered to get closer to the appearance of DAC V800.
The milling around the volume knob has more diameter so that the scale is now in the deeper area.
The milling around the phone jacks was altered to be more straight also the milling around the power knob was slighly changed.
See at
www.violectric-usa.com the new and actual style from V200 and compare it with the pics of V100 to have the look before.
