Bola 7
- Oct 2, 2011
ljokerl,
Sunrise Xcape IE or Fischer Audio Silver Bullet?
Thanks!
Thanks!
The problem has only cropped up once so far, it occured after around 8 to 10 hours of burning in over night.
So far with 2 hours of listening it has not occured. I suspect that it overheats after prolonged hours of usage?
Btw, the left driver is printed with a R instead, took me long enough to notice it lol, didnt bother to send for RMA once again.
ljokerl,
Thanks!
update: The strangest thing is happening and I'm trying to narrow it down. Occasionally one ear or sometimes both will go quiet and sound dampened while listening. If I take the phones off for a minute or two they go back to normal. It's not the cable or the fit. When this happens I switch ears to make sure and even carefully listen to them without the tips. I thought it might be ear wax but it looks real clean. Just wondering if this happens to anyone else.
ljokerl,Are there similarities of sonority between the Sunrise Xcape IE and the Monster MDT?Thank you!
Anyone knows where can i still get SW-Xcape v.1?
