cj42
- Jul 4, 2013
i want to confirm, so with that adapter cable, it will make the MH1's compatible with regular 3.5mm mp3 players? (eg. sansa clip etc)
with that adapter i can listen to music on my laptop and on my galaxy s phone - the mic works too , the only issue is the functionality of the buttons (there are apps that can map the buttons to do certain functions though, but i didn't mess with them .. i can answer calls by pressing the middle button - and mute the mic if i press it again during the call lol)
if you don't want to use the mic at all, you don't even need the adapter , you can put something hard (i rolled some paper) and put it on the middle button and then roll some tape around the controller so the middle button gets permanently pressed down (i did this and i could listed to music normally on both my cellphone and my laptop , during the time i was waiting for the adapter to arrive). that way the ground and mic connectors will be shorted and act as ground and it will become like normal TRS connector
