rlisin
- Jan 20, 2017
I have the quad SE-Q 404 from the same line as your SE 305 and with the same drivers I think, and those do not sound good at all, at least compared to modern headphones they don't. I actually had to swap 2 drivers for new substitutes because one was DOA and the new ones sound much better. Unfortunately I don't remember the exact model of headphones I got the drivers from, but they were cheap Monacor headphones from 5-10 years ago. Looked similar to the current MD-4600 model.
Come to think of it, my SE-Q 404 are another candidate for a Philips driver transplant. Thanks for reminding me!
Edit: Back to the SHL3300, I tested mine today with Beyerdynamic COP earpads and grille on and off.
Comfort is better with it off, my ears touch the grille when it's there - barely, but it can be annoying after some time. The 1mm depth difference with the grilles off was all I needed not to have this problem.
Sound-wise, unfortunately in combination with COP pads these headphones actually sound better with the grilles left in place. Like I wrote earlier, COP pads emphasize treble so removing the grilles (that also results in more highs) makes the sound unbearable, for me at least. And I like Beyerdynamic headphones and Sennheiser HD700.
With the grilles on they are still quite bright but not annoyingly so. So I keep the grilles in place for now and probably put something under the earpads to slightly increase their depth. Maybe I'll try with grilles off and a cloth filter (the test I did was with grilles removed and no cloth between ear and driver).
I might also try opening the vents a bit more (the ones on top of the cups), see what it does to the sound.
